Can vray hair mtrl 3 color propagate from underlying mesh material?
I'm doing some hair tests. Is there any way to take the hair color (which is set in the vray hair material) and have the color propagate from the color of the underlying mesh?
Unfortunately no. For Maya Hair, we don't have any information that would allow us to make a connection between the hairs and their source geometry.
It should work for VRayFur though.
It works with me, or i am wrong ?
I use the "hairColor" from the "VRayHairSampler" node, and connect the same texture in the "hair color" of the hairSystem and the sphere.
It's a bit manual setup though; I thought evanerichards wanted the color to be automatically taken from the diffuse color of the sphere material... or am I wrong?
If i understand my trick/hack :
There are FollicleShape which put the hairs. Each follicle have "parameter U" and "parameter V", based of the UV of the sphere.
When you connect a 2d texture in the hair color of the hairSystem, the hair will take the color of the 2d texture based of the U and V of the follicle. So, the hair will take the same color that the sphere.
So, if i connect the "hairColor" of a "VRayHairSampler" node on the VRayHairMtl, the "VRayHairSampler" will take the color of the hair color of the hairSystem (so, the color of the mesh).
Yeah, this is what I ended up doing and it worked. I connected the R G B channels from the color out of my image to the R G B of the VrayMaterialHair 3 primary colors and overall colors and BAM! It works.
good stuff.
So I think I made this work. Its based around the same example as I posted in post before, however I modified it to work with maya hair. I didnt test it on 2.4 branch but in 3.0 it works. Give it a try.
