Can anyone explain vrayMultiProjection?
  • Can anyone explain vrayMultiProjection?
    Hi all
    is this a tool to aid matte painting projections?
    doug
    -DW
    -buck.co
    It blends the result of several different projection nodes based on the distance from the projected camera. Optionally, it can also take as input a z-depth image for each camera to take occlusion into account. If you are interested, I can post a sample scene.
      Hi Vlado
      This does sound useful. Its hard to imagine how it works without seeing it setup. We may experiment with the node but a sample scene and any thought on the practical purpose of this node would be good. We can imagine using this to project multiple views of the same setting onto the same geo, using different cameras. does that sound right?
      -DW
      -buck.co
        Originally posted by dougWilkinson View Post
        Hi Vlado
        I have used it :
        - i have rendered a lot of spherical camera
        - after, i have added all rendered images into this node, and projet all renders in my scene.
        All projections were blended. Big camera mapping, fast render.
        www.deex.info
          ahhh. that sounds really neat. would like to try that on a city block with some HDRs from lots of angles!
          doug
          -DW
          -buck.co
            Originally posted by bigbossfr View Post
            I have used it
            So did you end up using it for final shots eventually, or you did something else?
              I have used it for 1 shot (camera movements (columns) were a big problem for others shots), and it works ^^.
              www.deex.info
                Hi! Can anyone post sample scene please?
                  Vlado is possible to see an example please? Thanks
                    Yes, let me find it...
                      Here it is:
                      https://ftp.chaosgroup.com/vlado/vra...multi_proj.rar
                      The scene has two layers, the master layer uses the VRayMultiProjection node to render the geometry, while the layer1 layer is set to produce the spherical projections (you need to render each of the three spherical cameras in turn).
                      The "zdepth offset" parameter can be used to deal with artifacts that sometimes appear when blending the different projections.
                      Let me know if you have any questions.
