I have a scene with approximately 13,000 instances of a V-ray proxy of a small patch of low-poly grass. The scene itself weighs in at 57MB (contains a house and car model). When I try and load this scene, it basically hangs Maya. I waited 5 minutes then ctrl+alt+deleted out of it as I figured it had locked up. I have 16GB of RAM.
These proxies were instanced using the scatter tool found in Ninja Dojo, though the same thing happens if I try instancing them with icPolyScatter or LayoutTools. Whereas if I use particle-based instancing, everything is very quick. However as I'm not much of a scripter, controlling the distribution of my grass patches with particles is a bit hard for me, so using an option that individually instances each proxy is preferable (such as the tools I mentioned). The issue also happens if I simply instance the geometry without converting it to a proxy.
Why doesn't the problem occur when I use particles to do the instancing though?
Any ideas on how to get around this issue would be great
