python callback question
  • python callback question
    sorry. I am not familiar with python.
    How does it describe to define the parameter (flip_x, flip_y, fov) of plug-in, after creating Plugin with a Create() function as follows?
    Code:
    from vray.utils import *
    create('CameraDome', 'perspShape')
    Please let us know.
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    You can use the plgparams utility coming with V-Ray to inspect the parameters supported by all plugins.
    Here is an example for the CameraDome plugin
    Code:
    $ plgparams CameraDome
    Parameters for plugin 'CameraDome'
      flip_x: bool = false, Flip in the horizontal image direction
      flip_y: bool = false, Flip in the vertical image direction
      fov: float = 0.785398, Field of view (radians)
    Supported interfaces:
    The code for setting parameters should be something like:
    Code:
    plg=create('CameraDome', 'test')
    plg.set("flip_x", True)
    plg.set("flip_y", False)
    plg.set("fov", 0.6)
    Hope it helps.
    p.s. keep in mind that the name of the plugins doesn't match the name of the nodes in Maya.
    V-Ray developer
      Thanks for the info. It was very helpful.
      Thank you very much.
      oakcorp.net
      v-ray.jp
