Creating renderElement in python scene access
  • Creating renderElement in python scene access
    Is it possible to create renderElements with the python scene access. I know how to create lightSelects and multimattes, but how do I create elements like specular, diffuse, relfection etc.
    I have tried creating the channel with: specChannel = create('RenderChannelColor', 'specChannel')
    How do I set the channel to ex. specular?
    Jacob
    Jacob Børsting
    Head of Pipeline @ Ghost VFX
    I will try to explain my workflow when i work with python scene access :
    Example : i want to create a specular renderElement in python scene access.
    1) I create a empty scene, and create a specular renderElement in Maya.
    2) In the Translator Options tab, i disable "render", and enable "Export to a .vrscene file". I set the file name, where i want to export the vrscene.
    3) I click on render.
    4) Now, i open the exported vrscene with a text editor.
    5) You will see your previous specular renderElement in the vrscene.
    6) Just copy the type, the name.
    For example, for the output plugin, we will have :
    Code:
    SettingsOutput vraySettingsOutput {
      img_width=450;
      img_height=337;
      img_pixelAspect=1;
      img_file="tmp/untitled.png";
    The type of the plugin here is "SettingsOutput", the name is "vraySettingsOutput".
    Found your previous specular renderElement plugin in the vrscene
    7) Create it : create(pluginType, pluginName), in your python script.
    Done.
    www.deex.info
      Thanks alot bigboss. That approach makes it pretty simple to figure out how to create the different channels.
      Jacob
      Jacob Børsting
        You need to set the "alias" parameter of the channel to something that V-Ray understands. As bigbossfr suggested, you can look at existing .vrscene files to figure out the correct numbers. They are also defined in the pixelbuffer.h file from the V-Ray SDK.
