Global options - Max Depth
  • Global options - Max Depth
    Hi all,
    is there a way to set the 'Global max depth' for reflection and refraction independently?
    cheers,
    Steve
    Originally posted by sherridge101 View Post
    Hi all,
    cheers,
    Steve
    You can in Python Scene Access...
    1) Get all materials
    2) Set all materials
    Do not forget that in render global, the "max depth" in an override depth, not a clamp depth...
    www.deex.info
      Hi bigbossfr,
      great, thanks for that.
      Would that be something a non programmer (like myself) could do?
      cheers,
      Steve
        Hi bigbossfr,
        cheers,
        Steve
        Sorry for the late reply. I did this in 5 mins :
        Code:
        import vray.utils as vr
        def setMaxDepth(reflMax=None, refrMax=None):
            refracAttrs = ["refraction_depth"]
            reflecDepth = ["trace_depth", "reflection_depth"]
            for node in vr.findByType("*"):
                allAttrs = vr.getPluginParams(node)
                for attr in refracAttrs:
                    if refrMax and attr in allAttrs and int(node.get(attr)) < refrMax:
                        node.set(attr, refrMax)
                for attr in reflecDepth:
                    if reflMax and attr in allAttrs and int(node.get(attr)) < reflMax:
                        node.set(attr, reflMax)
        setMaxDepth(reflMax=20, refrMax=10)
        Add this code into "Post-translate python script" in Maya render global ---> VRay common
        Change this last line with you max depth : setMaxDepth(reflMax=20, refrMax=10)
        If you want just max reflection depth to 20 : setMaxDepth(reflMax=20)
        If you want just max refraction depth to 20 : setMaxDepth(refrMax=20)
        Or both : setMaxDepth(reflMax=20, refrMax=20)
        Vlado : i see an attribute : mtl_limitDepth in vraySettingsOptions. It is what i am thinking ? (a clamp?)
        www.deex.info
          Nope; it's the same the global V-Ray option in the Maya interface, so it's an override, not a clamp.
            Awesome, cheers bigbossfr.
