Any way to toggle multiple render elements at same time?
  • Any way to toggle multiple render elements at same time?
    Hi there,
    I was wondering if there's any way to toggle multiple render elements at same time.
    The project I'm working now, I reference same character file multiple times which has same multi matte set.
    Now I have to click this on/off icon to every single elements.
    Is there any way to do it at same time?
    Have you tried to select multiple render elements and then to toggle the Y/N icon?
    V-Ray developer
      Yes, I tried and No, it does not work that way. It's only toggle one element with its icon, not every selected ones.
      Oh wait, does it work that way for you? If it does, which version of maya and vray are you using?
        Maya 2014, V-Ray 3.0 dev version
        I've not tried 2.45 or any other release.
        What is the version you're using?
        V-Ray developer
          As far as I can see, this will only be available in V-Ray 3.0.
          V-Ray developer
            Oh, then if maya 2014 and vray 3.0 are working that way, I just have to wait til it get released : )
            I'm using maya 2013, 2.30 and 2012, 2.20, none of them isn't working for multiple elements toggle.
              Why not using the spreadsheet editor?
              Select your RE and switch them on/off.
              Only problem it doesn't refresh in the render setting window. it needs to be close and re open to see the change.
              Yannick
              Portfolio: http://www.cgifocus.co.uk
                I guess that's only option for now til vray 3 comes out. Thanks Yannick!
                  Yannick
                  Yannick,
                  I just tried to select my RE"S" and it's not letting me select multiple REs.
                  Is your maya+vray working that way fine? If then, what version are you using it?
                  My computer's maya is 2013, vray is 2.25.01.
                    I tried on Maya 2013 and Vray 2.30.01
                    You need to select your RE in the outliner.
                    Cheers,
                    Yannick
                      Oh, that was the trick! It works. Thanks!
