Query batch camera rendering
  • Query batch camera rendering
    Maybe this is not a specific V-Ray question, but it is for Maya and rendering with V-Ray, so I'm not sure where else to ask?
    Is there a way to query the exact current render camera during a batch render?
    Maya 2020/2022
    Win 10x64
    Vray 5
    You can check out vrayBatchRender() in vrayRegisterRenderer.mel if you want this badly. $batchCamera can be used to get the current camera. However currently it's not global. I will make a note to implement "vrend -q camera".
      Thank you. That is very helpful.
      Maya 2020/2022
      Win 10x64
      Vray 5
        Hi snivlem,
        Just to clear things up, did you mean that you want to query which camera renders at the moment during the batch render in Maya GUI?
        Alex Yolov
        Product Manager
        V-Ray for Maya, Chaos Player
        www.chaos.com
          Here's the hacky code snippet I use. However, I'll look into $batchCamera like ivaylo suggested.
          Code:
          global proc string vraySubmit:getRenderableCamera(){
                  //returns first renderable camera
          	string $cameraList[] = `listCameras -p -o`;
          	string $renderCamera;
          	for($camera in $cameraList){
          		int $renderable = `getAttr ($camera + ".renderable")`;
          		if ($renderable){
          			//setAttr vraySettings.batchCamera -type "string" $camera;
          			$renderCamera = $camera;
          			break;
          	return $renderCamera;
            In PyMel, one line :
            Code:
            import pymel.all as pm
            renderCameras = [x.name() for x in pm.ls(ca=True) if x.renderable.get()]
            www.deex.info
              Originally posted by yolov View Post
              Hi snivlem,
              Yes, I aim to have code in the MEL prerender, so I can get the exact name of the camera that will be used during the batch render.
              So for example, in my batch render scene I have these as renderable cameras.
              Camera1
              Camera2
              Camera3
              Camera4
              So when V-Ray starts rendering through Camera2 I can query this via pre render MEL and it returns the exact value "Camera2"...NOT the other cameras.
              In Maya GUI it is easy because of:
              string $renderPanel = `getRenderWindowPanel`;
              $camera = `renderWindowEditor -q -crc $renderPanel`;
              Maya 2020/2022
              Win 10x64
              Vray 5
                Thanks a lot for the reply. I messaged you with some more questions to find the most suitable way to implement this.
                I guess it would be best to call "vrend -q camera" (implemented already for this issue) from pre render MEL.
                V-Ray for Maya developer
