Naming vray object properties nodes on creation?
  • Naming vray object properties nodes on creation?
    Is there a way to name the vray object properties node on creation?
    I want a way to mel script this so that I can create VrobProp (Vray object properties) nodes based on the selected object they are attached to.
    Like if pPlane1 is selected and I apply a VrobProp setup with the right attributes checked for it to be a shadow catcher. So essentially making a little button that is "Make Vray Shadow catcher"
    Then the pPlane1 name is applied to the VrobProp when created. This way when i have multiple vrayobject properties nodes in the outliner they don't just appear as
    vrayobjectproperties
    vrayobjectproperties1
    vrayobjectproperties2
    vrayobjectproperties3
    But rather how I want to see them so they are associated with the objects/groups connected
    VrobProp_pPlane1
    VrobProp_pSphere1
    VrobProp_pPlane2
    VrobProp_Wheels_Group
    Then I can easily see that the wheels_group will have the motion blur override
    The planes are shadow catchers...
    .. and the sphere is matte zero.
    Even though I would have to click through them at least I can tell at a glance what I attached them to.
    Currently I just rename them manually but I wanted a way of naming on creation so that the mel script is easy to track.
    I mean I could always
    Code:
    vray objectProperties add_single;
    connectAttr vrayobjectproperties1.outConnect vraySettings.vray_nodes_connect -nextAvailable;
    Then rename the vrayobjectProperties node. Maybe do a check to see if vrayobjectproperties1,2,3 etc exists.
    But.. Is there a flag for naming the vrayobjectproperties on creation?
    KC
    No there is no way to set the name at the creation time at the moment, sorry.
    I'm thinking that instead of adding a parameter to allow you to specify the name a better approach is to return the path/name of the created object.
    This way we can make add_single and add_multiple to behave similarly. The former will return a single string, the latter will return an array of string.
    What do you think? Will this be behaviour be good enough for you?
    /Teodor
    V-Ray developer
      Yeah that could work. I mean any data input is fine because we could always catch it in a string $variable[] and end up where we want right?
      KC
        Ok, I've added it to our ToDo and we'll notify you when we've implemented it.
        Is this something you need urgently?
        V-Ray developer
          Well, I can work around it for now so not really urgent. Besides I can't implement a new build at the moment. So when it gets implemented I'll start utilizing it at that point.
          Thanks.
          KC
            Btw, I just noticed that the
            vray objectProperties add_multiple;
            Does append the transform name to the VrobProp node.
            This will be fine for now.
            KC
              The "vray objectProperties add_single/add_multiple" commands now return a string array with the names of the newly created object properties nodes.
              You can check it out in the nightly builds
              V-Ray for Maya developer
                For vray 2 you will have to wait till next week for the next nightlies (the 3.0 ones already got this feature)
                  Ok, thanks.
                  Currently I am using am naming the node on creation with the create node command as a workaround.
                  Code:
                  createNode -name $namedNode VRayObjectProperties;
                  KC
