I know this subject has been discussed before but I could find a solution in order to add the vray attribute to several curves.
Is there an easy way? A mel somewhere?
Could we have the attribute to be added to the object property? That way I could select all my curve at the object property and then add the renderable attribute in the object property.
Also in the renderable attribute, the value gets cut to 0.0 if you for example put 0.001.
Thanks,
Yannick
Thanks,
Yannick
