How to NOT render on the local machine when distribute rendering
  • How to NOT render on the local machine when distribute rendering
    I am working on one machine and would like to use distributed rendering. However, even if I configured 2 other machines in the DR settings, my local machine's CPU is highly used during render.
    How can I remove it from local rendering ?
    Thanks !
    The ability to remove the localhost from DR is only available in V-Ray 3.0 - the checkbox is in the DR settings window
    depending on your OS, you could adjust the process affinity so your host machine isn't completely choked up on the rendering process
    Brendan Coyle | www.brendancoyle.com
      I'm pretty sure its also available in Nighties for 2.4....
        They're still updating 2.4?! Why did I upgrade
          Thanks for your prompt answer. As I would like the local machine really not to render, it seems that patience for version 3 will be the rule.
          I am on Maya/Mac.
          Cheers, Laurent
            I am on Maya/Mac.
            Cheers, Laurent
            Or just get nightly for 2.xx and you will have it today
              Sorry for the stupid question but where can I find these nightlies ?
                Email support@chaosgroup.com and ask for access I suppose.
                  Another workaround option is to set the number of threads to 1, this way V-Ray will use only 1 thread.
                  V-Ray developer
                    I have downloaded the latest nightly and indeed I can remove the local machine now, thanks for the good tip !
                    However the Linear Workflow in the color mapping is not supported anymore, I temporarily rolled back until I find the right settings to compensate its absence.
                      That function will not come back. If you used it then your Gamma workflow might be incorrect and you would need to learn the proper way of using gamma...
                        In fact it should work as before, but it will just print a warning for now.
                        V-Ray developer
                          No, it has not been removed, V-Ray just prints a warning.
                            Where are this "thread" option in vray 2.4 for max?
                            Thanks
                            • #15
                              Open a MaxScript listener and type
                              Code:
                              renderers.current.system_numThreads=1
