Hi what is the best way to speed up the Env Fog for Vray Im rendering 9K I got some light on the scene and that's about it ... the frames are taking 1:20 min a frame which I believe is a little much ...
Thanks
-decreasing Subdivisions value
-turning OFF Scatter GI, or if you want to use that option then decrease Scatter GI bounces
-increasing Cutoff Threshold value
If you are using 3D texture to control the Environment Fog you may also consider:
-increasing Step Size
-decreasing Texture Samples
Changing all these parameters will also affect the quality of the fog.
