Render sequentially multiple cameras
  • Render sequentially multiple cameras
    I have a Maya scene and would like to render frames 1-200 with camera1, 201-400 with camera2, 401-1000 with camera3, aso.
    Can this be done with VRay in one render operation or should I initiate multiple renders manually ?
    Thanks !
    U can create render layer for each camera and then render all layers one after another.
      Thanks. Should I simply set a different camera in the Renderable Camera setting and Maya will automatically take it ?
        I think that should work... not sure. There might be bug with it tho. Remember to create layer override.
          Originally posted by lcrivell View Post
          Thanks !
          Use command line rendering, just open notepad and some code:
          "C:\Program Files\Autodesk\Maya2015\bin\Render.exe" -r vray -cam camera1 -s 1 -e 200 "D:/maya/projects/project.mb"
          "C:\Program Files\Autodesk\Maya2015\bin\Render.exe" -r vray -cam camera2 -s 201 -e 400 "D:/maya/projects/project.mb"
          More commands and tutorial that you SHOULD read
          http://www.jawa9000.com/Technical/ba...-rendering.htm
          Then save as render.bat on your desktop - done!
          Maya 2020/2022
          Win 10x64
          Vray 5
