Universal Settings scene.
  • bigbossfr
    replied
    Vlado, whats about this universal settings :
    AA min : 1
    AA max : 10
    AA Threshold : 0.010
    DMC Sampler subdivs mult : 0
    Min shading rate : 16
    It works great (with BF + LC GI) !
    Leave a comment:
  • Svetlozar Draganov
    replied
    Universal settings control the image quality via single parameter - Image Sampler Threshold. Hence controlling the separate properties of the scene is not the main aim of this approach.
    In general if something is noisier you have to just decrease Threshold value until you get the noise-levels you are looking after.
    However it is still possible to use DMC Sampler and secondary rays subdivisions in order to decrease the amount of noise locally but you have to have in mind that the number of the subdivisions should be much greater (usually x10) comparing non-universal approach due to the fact that by default Vray subdivides secondary rays subdivisions by the max AA subdivs. In Vray 3.x we've introduced an option to disable that internal subdivision called "Divide Shading Subdivs" which will force Vray to use the user input subdivs without subdividing them, so you don't have to bump them to extreme values.
    If this option is activated which is by default there will be almost no difference between 8 and 16 glossy subdivisions since they both will be subdivided by 100 - in order to get a desired noise reduction you should use value like 160 or more depending on the rest DMC Sampler settings like Adaptive Amount / Adaptive Threshold / Adaptive Min Samples and Min Shading Rate(in version 3.x).
    Another quick approach to increase the quality of the DMC rays globally would be to use Subdivs Multiplier into DMC Sampler Settings.
    Leave a comment:
  • Dariusz Makowski (Dadal)
    replied
    Ok back to Universal sampling topic...
    I did some hi res tests and so on. All and all I can say that I'm quite impressed. Works very well with scalability from 1k prev to 8k final render.
    The problems I run in to are:
    1. Utilities. When I try to get diffuse pass and refl_Filter pass. They are very noisy and bad. I have to jank up min AA to 5 to render them smooth. Is that a proper workflow?
    2. Is there a way to control quality per err type? Atm we have AA threshold which control all but can I somehow control quality of Lights separately to one on reflections and refractions? I find that most of my tests produce acceptable light source BUT reflection pass is about 50% below where I need it to be.
    So for point 2 should I just increase materials refl glossy samples to 16 which would double in effect their quality in final render? Would that work?
    No GI tests so far so no comment on that.
    Leave a comment:
  • bigbossfr
    replied
    Originally posted by Dariusz Makowski (Dadal) View Post
    For flat colors there should be vray node called VRayUserColor. It should give you the right gamma accurate colour.
    You also have VRayUserScalar for alphas.
    VRayUserColor is not for this. It does not give you the right gamma, this is wrong.
    If you want the good and optimized color , create a color correct node from VRay texture, set your color, set the gamma to 2.2 (not exactly srgb but...). Now set the same color into your material color (diffuse color, spec color...) from the swatch of your color correct (the swatch is gamma corrected).
    Delete the color correct. Done.
    Leave a comment:
    replied
    Originally posted by drew_almighty View Post
    I do use this for image files but you can't do this for colors set directly in the diffuse swatch. Not trying to threadjack, just sayin....
    Leave a comment:
  • Lupaz
    replied
    Is there a file like the one Vlado attached but for MAX?
    I'm sorry if there is one in the forum but I don't know how to search for it.
    Edit: Oh, this is Maya only forum. Sorry!
    Leave a comment:
  • drew_almighty
    replied
    Just use in file node the extra vray attribute to correct your gamma. Dont use the mayas gama node thini..../
    Leave a comment:
    replied
    Just use in file node the extra vray attribute to correct your gamma. Dont use the mayas gama node thini. None the less back to topic.
    I had to roll back to 2.4 for a while and over ther it seem to work very well. Actually I'm quite stunned how good it works and how well it scales from 1k resolution all the way up to 8k. Before I had to redo a lot of materials as the render ended up being 24h long where my expectations vere 20 min. None the less need more testing but so far, well curse me for being old fashion and trying to control all settings :/
    Leave a comment:
  • drew_almighty
    replied
    Sorry, I just saw the linear workflow post above and wanted to cover all the bases. Thanks for the feedback.
    Leave a comment:
  • vlado
    replied
    Vlado, using these settings are you putting gamma correct nodes on your shaders for straight diffuse colors (not derived from external images) when rendering with V-Ray for Maya? Why or why not?
    Eh, do we have to get into that The universal settings as such have nothing to do with the gamma workflow, they are just for image sampling. In general, the gamma nodes will slow down the rendering - they take a bit of time to compute even for a solid color, so I would avoid using them even if only for that reason. I hope that Maya will implement a better color management solution soon.
    Leave a comment:
  • drew_almighty
    replied
    Leave a comment:
  • vlado
    replied
    Hmm, the today's 3.0 builds do not have the "Don't affect colors" option; it has been renamed to "Mode" and its default value is "Color mapping only, no gamma". I just verified and it saves correctly an .exr file that looks fine.
    Leave a comment:
    replied
    Oh yea crap the double gamma has me . I just rendered ur scene straight away. So now that confuses me !
    Proper gamma workflow - jezus I cant believe I'm asking for this...
    Save as EXR
    VFB = Display color in SRGB space
    Color mapping
    Gamma 2.2
    Dont affect colors, only adaption.
    Incoming textures any 16/8 bit enably vray gamma in file node.
    Is this correct or I'm wrong?
    I've also updated vray to today's version
    Leave a comment:
  • vlado
    replied
    So do you mean AA Adaptive DMC Threshold or DMC Sampler threshold ?
    The one in the image sampler section.
    And am I right that I should not increase any of the material/lights/etc samples right? Just threshold? And that I can control AA threshold separately to fine tune AA/edges right? OR should that be "Lock Threshold to dmc sampler threshold" on ?
    Don't touch anything else.
    Here is a render with dmc sampler threshold set to 0.0001... I must be doing something wrong because it took long to render and its noisy :- (
    You have double gamma on your image - it makes it look a lot noisier than it actually is.
    Btw this was done with the latest 3.0 nightly build; if you used an older build, it might not come out quite right (there were some changes in the color mapping settings).
    Leave a comment:
    replied
    Thanks Vlado !
    you can use the noise threshold for the "Adaptive" sampler to control the quality
    I'm pretty much re-asking what I think I read in past but I'm not sure if that's 100% correct tbh.
    Leave a comment:
