Defaulting VFB to use OCIO Correction with Envars
  • Defaulting VFB to use OCIO Correction with Envars
    Is there an environment variable that can be set that will set the VFB to default to OCIO correction? Currently I see envars to control sRGB or Lut enable (and associated lut file) but nothing for defaulting the VFB to start with OCIO.
    http://docs.chaosgroup.com/display/V...ogrammatically
    Thanks for any info,
    Ayo
    You can use the environment variable VRAY_VFB_OCIO=1 to enable the OCIO color correction (you might also need VRAY_VFB_SRGB=2 to disable the sRGB). The OCIO profile itself is specified with the OCIO environment variable, and the input color space, display device and view transform - with the environment variables VRAY_VFB_OCIO_INPUT_COLORSPACE, VRAY_VFB_OCIO_DISPLAY_DEVICE, VRAY_VFB_OCIO_VIEW_TRANSFORM respectively.
    In Maya, you can also use the "vray vfbControl" MEL command to control these things.
      Works perfectly. Thanks Vlado.
      Is it safe to assume that if VRAY_VFB_OCIO_INPUT_COLORSPACE isn't set that the reference or scene_linear roles defined in the OCIO config file are picked up?
      Thanks again,
      Ayo
