Commandline rendering with VFB option "Curve" enabled
  • Commandline rendering with VFB option "Curve" enabled
    Hi (again),
    In V-Ray 3 (latest nightly), when I batch render (commandline) with the VFB's "Curve", "Levels" etc options enabled, it doesn't seem like these effects gets burnt into the actual image. It only works when you render in the VFB/GUI.
    Is there a global "post effects" toggle somewhere that I need to enable?
    Best Regards,
    Fredrik
    VFB color corrections could be saved into the image only when rendering through VFB for the moment.
    I'll add a note about ability to burn color corrections with Maya Batch.
      This has been actually reported already and we have a developer working on it right now.
      We'll keep you posted.
        Allright, thanks Svetlozar!
        Best Regards,
        Fredrik
          Yeah, by a bit of coding misfortune the code for the color corrections is very tightly coupled with the actual UI code and if the UI is not there, the VFB can't apply the color corrections. As Svetlozar mentioned, one of the developers is working on this now.
