vrayMtl2sided render Element
  • vrayMtl2sided render Element
    Hi all,
    is there a way to get the contribution of a vrayMtl2sided in a render element ?
    when I rebuid may beauty in comp (lighting+gi+reflect+spec+refract), i can't have the same result as i have in vray .
    and i tried with the sss RE without any succes.
    For info i use vrayMtl2sided with only the front side in order to get some translucency in my vegetation.
    Thanks.
    Not right now, but it is on the "to do" list to put the translucency on a separate element.
      what I do is rebuild the diffuse + lighting and gi and reflection/specular then subtract that from rgb and get the scatter component (its not the best way) but it gets you that control.
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
        ok, thanks for the quick answer guys !
