VRay + xGen : possible to create per-spline texture mapping?
  • VRay + xGen : possible to create per-spline texture mapping?
    Hello,
    I'm struggling to find a way to map individual splines (groomable) with an opacity cutout texture - think feathers. From what I understand this is how they created the feathers for the pidgeons on Bolt. All I can control so far is root_color and tip_color, but can not map any kind of texture (colour / opacity etc) to the actual splines (projections wouldn't be applicable in this case).
    Does anyone have any useful info on whether this is indeed possible in Vray with a combination of VRayUserColor / VRayUserScalar / VRayHairSampler etc? And if not, whether it is a feature that will be worked on?
    Thanks,
    Geoff
    Currently no. We will think on this in the future though ...
    V-Ray for Maya developer
      Hi Viktor,
      Thanks for your (disappointing) reply
      I for one highly recommend that you do look into this as it opens up such a huge workflow advantage being able to use the splines rather than archives for feathers - the grooming tools alone make it worthwhile.
      With Renderman there are shader modules that allow access to XGen data, like object id, primitive position, per-spline colour, per-spline opacity etc, which is what they used for Bolt: http://i.ytimg.com/vi/EIFP3nWL5I8/maxresdefault.jpg All those feathers are XGen groomable spline primitives!
      Imagine being able to do that in VRay
        Yep, we will get there, hopefully for SP2.
        V-Ray/PhoenixFD for Maya developer
          Hi! I know this is a really old post but I was wondering if this issue has been resolved in newer versions of Vray?
          I would really like to apply an oppacity map to individual splines for an illusion of a feathers.
            Already implemented. Check the docs on how to use the feature.
