Rendering transparent shadows?
  • Rendering transparent shadows?
    I have a product setup in maya 15 and vay 3
    I am trying to render the product against a white or black background with a transparent shadow.
    Currently I am using the material wrapper setup like so; http://polygonspixelsandpaint.tumblr.com/post/963324234
    base material is just a basic vray material.
    my render is coming out showing the ground plane though and I am not getting transparency. The alpha also just shows a solid plane with no transparency for the shadow.
    how can I get just a transparent shadow and not see the whole ground plane?
    Can you post your scene file to check the entire lighting and material setup? If there are any confidential models or textures, you can replace them with simple primitives.
    Tashko Zashev | chaos.com
      I replaced the geometry with a simple primitive and archived it so I can share with you, how do I attach it here in a post though?
      If you send me your email address I can email it to you, but I still wonder how to post such things here.
        You can add file attachments only in Advanced post mode. Just click on "Go Advanced" button on the bottom right side of the page. Then you will see a new "Attachment" icon on the toolbar.
        Or you can send us the file (or a download link) to support at chaosgroup.com
          thanks, here is the scene.
            Thank you.
            I see that you are using a V-Ray dome light for this setup. It produces very soft shadows on the ground plane and makes it visible in the final render.
            So you can either decrease (can be set to zero) the "GI amount"parameter in the V-Ray Wrapper material > Matte properties section, or uncheck the "Affect alpha" option in the V-Ray Dome light attributes.
            Let me know if this helps you.
              Thanks for looking into it
              I tried both of your suggestions and saw no difference though. Also turned off the dome light and tried using a vray rectangle light, and still saw no difference with how the plane is behaving.
                As far as I understand you're trying to render the plane as a matte object (shadow catcher), is that correct?
                If this is the case, there's a couple of ways to do that - either using a wrapper material or vray object properties. There is a wrapper Mtl in your scene, but it's not assigned to the ground plane. The wrapper settings are correct, though.
                Alex Yolov
                Product Manager
                V-Ray for Maya, Chaos Player
                www.chaos.com
                  haha oops! Thank you so much for taking a look, it is working now
                    Good to hear
                    Alex Yolov
                    Product Manager
                    www.chaos.com
