redner on white
  • redner on white
    Hi GUys,
    Hoping someone will think of something I've missed! so I've picked up a job from someone who's left the company & it's a bit of a mess to say the least! I've done a clean up but it's rendering on white & I cant for the life of me figure out why! I've checked lights, background env settings, the env col tab in the camera slot, its using a physical sun/sky & I've turned these off also.. but whatever i do it renders on white!
    any ideas ?
    Thanks
    Chris
    Have you checked the V-Ray environment slots in the Render settings/ V-Ray tab ?
    There might be hidden lights in the scene as well. Or light materials ...
    Tashko Zashev | chaos.com
      Hello,
      You can try to reset your render settings and see if this helps if it isn't - then it's something in the scene (check if you have layers, geometry with self-illumination). If it's using sun and sky, most probably it's using physical camera too - check the settings on that one as well. If you still have trouble - you can send us the scene and we'll try to figure it out.
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
