Micro Scraches
  • Micro Scraches
    I am trying to translate a Vray & 3DStudio Max tutorial and i just cant get it.
    here is the tutorial:
    http://viscorbel.com/microscratches-...vray-tutorial/
    In the tutorial he said he adjusts the GAMMA to control the falloff. I cant fine ANYTHING relating to GAMMA, I think its in the 'Normal Bump Map' utility inside Max.
    I have tried this 4-5 different ways and i cant get ANYTHING CLOSE to his sample renders. any help would be appreciated.
    Duff
    You can add the "Texture input gamma" V-Ray attributes to a File node and control the gamma of the texture from there; see here for more information:
    http://docs.chaosgroup.com/display/V...tureInputGamma
    Note that the value is reverse to the one in 3ds Max (i.e. 0.45454 in 3ds Max corresponds to 2.2 for the Maya attributes).
      Gamma doesn't 'control' anything in that tutorial - setting it to 1.0 just makes sure 3ds max loads normal map properly.
        If "Gamma doesn't 'control' anything in that tutorial" what is the setting thats he is stepping down to control the fade off of the layers in the VrayBlendMtl ? because he said the the BUMP VALUE is set to 30. That is insane inside maya so im assuming its something between .2 to .01.
        This is why I was hoping to have someone translate this into Maya, because I cant figure this out.
          I have made a little progress. Turning off the image filtering made a HUGE difference. But Still can't get the layer falloff working yet.
            The thing that I stepped down for the layers is Normal bump strength.
            I don't know how it works in maya, but in max you can change the bump strength in 2 ways and have an identical result - the normal value inside the NormalBump texmap or the actual Bump amount (default 30)
            In this tut, i chose to change the normal strength, instead the default bump value. Doesn't really matter.
