Render Mask?
  • Render Mask?
    I've just tried the render mask feature to get out of a tight spot, using a geometry set to just render a single object in the scene
    Interestingly, the render buffer isn't cleared between frames so in a batch render I get that 70's music video effect where every frame builds upon the last, and objects leave trails around the screen. Is this intended behaviour?
    No, it is not, it should automatically clear in animation. Does forcing it with the "Clear frame buffers" works? It's in render settings > common tab > render view section.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Thanks. I just tried it and it did not appear to help.
      This time I used an animated rotoshape from Nuke as a texture mask but the problem persists. If it makes a difference I'm creating the scenes in OS X and rendering on Linux.
        No it doesn't, unfortunately
        I'll log it as a bug and we'll fix it. Thanks for the input and I apologize for the inconvenience.
        Alex Yolov
        Product Manager
        www.chaos.com
          Thanks, I'm able to use the same matte in Nuke to trim away the trails so we can get by for the moment.
            One last thing, though - what VRay and Maya versions are you using?
            Alex Yolov
            Product Manager
            www.chaos.com
              Maya 2016 SP5 & VRay 3.30.02
                Hello!
                I couldn't reproduce the issue on my system. Is it possible to attach a simple scene with the problem, so we can try to reproduce it?
                Thanks in advance!
                Ivan Shaykov
                chaos.com
                  Hi Ivan, sorry I haven't been able to reproduce this yet because I've been working on a different project and possibly because I'm not using the same render farm at the moment. I should be able to try again in a couple of weeks.
                    I'm bumping up this old thread. Rendermask seems to behave as described below when doing animations (copied the very first post in this topic). Using Maya 2019.3.1 and Vray 4.30.02. Is it just me again ? I cannot imagine people are not using this feature in Maya animations.
                    www.mirage-cg.com
                      can anyone give help on that ?
                      www.mirage-cg.com
                        Hey waaazoo is this with V-Ray Standalone or with a maya batch render?
                        Alex Yolov
                        Product Manager
                        www.chaos.com
                          with standalone, but I tried also within maya.
                          www.mirage-cg.com
                            Thanks for confirming. There's an issue with Standalone, but it should work fine from Maya. If that's an option - try rendering from Maya (either from the GUI or with maya batch). I'll bump up the priority of the Standalone issue.
                            Alex Yolov
                            Product Manager
                            www.chaos.com
                            • #15
                              Hi, we've found the issue and we are currently testing a fix. We'll notify you when it's available.
                              V-Ray for Maya dev team lead
