Vray proxy with stitched alembic particle sequence.
  • Vray proxy with stitched alembic particle sequence.
    Hi Guys,
    Have a question about using a Vray proxy with a stitched Alembic particle sequence -
    Is it possible in the particle width multiplier to set a random value? At the moment it seems to work as 1 number for all the particles.
    Also is it possible to generate a multipoint at render time?
    Cheers!
    Will
    no, this is not possible. You have to export the alembic file with the desired properties.
    Asen
