Reflection subdivs for the vrayMtl are now greyed out when adaptive sampling is used. Is the same true for the oslMtl when using an OSL Blinn or GGX shader with a reflection subdiv parameter?
adaptive sampling and osl
Yes, it's the same with the only difference that we don't actually grey out the exposed subdivs parameters of OSL shaders, since they're using a different UI template. But if you set "use local subdivs" to "off" in DMC Sampler > advanced - then those subdivs value will be used just as any other shader or light's subdivs. When it is "on" they will be ignored.
