mapping vrayMtl refraction ior with falloff texture
  • mapping vrayMtl refraction ior with falloff texture
    Hello,
    I am trying to map the refraction ior of a vrayMtl with a falloff texture.
    I set the falloff texture front color value to 1.1 and the side color to 1.33
    and plugged that directly in the ior slot. (probably naive
    I tried the various falloff modes but I get no usable results.
    I also tried to use a RGB to luminance between the falloff tex and the ior,
    but this does not cut it either.
    So I guess it is more complicated than that.
    I would like to have the object (waterlike bubble) refract stronger
    on the sides and weaker on the front.
    Blending two materials with different ior's with a falloff texture
    renders a lot longer and feels somehow hacky.
    Appreciate any ideas on this.
    Armin
    This should work, does your bubble geometry have thickness?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      No it doesn't, it's solid. It's a subdivided cube, deformed and animated with a lattice and a texture deformer.
        you need thickness in geometry otherwise it will not produce correct refraction.
        Dmitry Vinnik
        ShowReel:
          Thanks for your help. Is it not possible to map the ior of
          a solid object i.e. a water bubble floating in zero gravity?
