dual GPU problems/setup
  • dual GPU problems/setup
    hi, I´ve insert a second GPU to my 980ti, a 1070.
    All works fine, incl. other GPU renderer.
    But now the IPR crashes everytime, when I start IPR in CUDA mode.
    I´v absolute no idea, if there is something to setup for vray, when working with 2 cards!?
    Please help, thanks
    Vray 3.5, Win10
    www.3dcompani.com
    ok, a look into the manual makes often sense
    The env variable wasn´t set correct and with one click in the gpu-setup tool from chaos, it was fine!
    ...but vray still chrashes in CUDA!
    With this messages...
    help please...
    Vray 3.5, Win10
    www.3dcompani.com
      Can you share driver version, V-Ray version and the log from the V-Ray console and Maya ?
      Thanks,
      Best,
      Blago.
      V-Ray fan.
      Looking busy around GPUs ...
      RTX ON
        maya 2015/2017 the same prob
        vray 3.4006 official and 3.5701 the same prob
        win10
        nvidia driver 378.66
        vray and maya log files - no idea where to find them
        Vray 3.5, Win10
        www.3dcompani.com
          In 3.40.06, when you start RT GPU a separate console process named vray.exe is spawned. It is basically a console with the log in it.
          It might be a good starting point.
          However, if you prefer we can skip all that and arrange a TeamViewer session with the support. It might be easier just to log in and check what is wrong.
          Best,
          Blago.
          V-Ray fan.
          RTX ON
            hi Blago, thats a great idea.
            How can we organize the TV session?
            Vray 3.5, Win10
            www.3dcompani.com
              ...and voila
              Vray 3.5, Win10
              www.3dcompani.com
                Write to support@chaosgroup.com with link to this thread
                Best,
                Blago.
                V-Ray fan.
                RTX ON
                  hi Blago, did you take a look onto my vray.exe output window screenshot?
                  Is there any intersting information to see?
                  Seems to be better, we figure it out in this way, should be faster than TV session - nothing happend!
                  Thanks
                  Vray 3.5, Win10
                  www.3dcompani.com
                    I took a look, but it is hard to say what is going on from the window. We should try a team vieiwer (guessing could waste some time).
                    Best,
                    Blago.
                    V-Ray fan.
                    RTX ON
                      Blado, since over 48 hours I wait for help.
                      And nothing happens. Thats hard.
                      What can I do, to get help from you?
                      The two cards itself are perfect working. As example is Redshift rendering with both and has no problems!
                      Vray 3.5, Win10
                      www.3dcompani.com
                        Sorry for the delay. I guess you mailed the support and you still have no answer back ?
                        Best,
                        Blago.
                        V-Ray fan.
                        RTX ON
                          one reaction came, then I sent back my tv data and possible times...
                          no reaction...
                          Vray 3.5, Win10
                          www.3dcompani.com
                            no reaction...
                            It takes few days to get an answer back. Mark your tickets which are emergency just so they know and they can react quicker.
                            I will make sure to handle this tomorrow (or asap).
                            Are you located somewhere in Europe or the time difference is bigger ?
                            In the meantime, may you try going to %appdata%/NVIDIA and deleting the "ComputeCache" folder just to make sure the driver is not messed up.
                            Also, which driver are you using ? May you try installing 376.XX ?
                            Best,
                            Blago.
                            V-Ray fan.
                            RTX ON
                            • #15
                              I´m located in germany. I think the timeshift sould be 1h!?
                              "In the meantime, may you try going to %appdata%/NVIDIA and deleting the "ComputeCache" folder just to make sure the driver is not messed up."
                              I tried to find the stuff, but didn´t.
                              I gone to user/"me"/appdata - no nvidia folder...
                              go forward into local folder, then into nvidia folder - no computecache folder...
                              pehaps you can "spell" me the location - for non computer freakes!?
                              I´ve installed newest gforce driver 378.66
                              Vray 3.5, Win10
                              www.3dcompani.com
