VRaySoftbox inverse square law
  • VRaySoftbox inverse square law
    Hi all
    Is it possible to link a curve (remapValue) in to the Horizontal Gradient slot on the VRaySoftbox?
    I would like to create an inverse square law curve for the light.
    Maya's remapValue slots in to the Horizontal Gradient's position, colour and interpolation by the looks of things, but I can't see a slot for the ramp.
    Cheers
    I'm not sure I understand this, could you help me out a bit? Where do you need to plug in a remapValue exactly? The Horizontal gradient is like a ramp - when adding new positions, you can plug in anything to their value (color).
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Hi Alex
      No worries. I may not have explained that correctly.
      I was thinking of using a curve, to match a light decay curve I grabbed from a pic online. This way I can control the falloff from point to point.
      Is this possible with the gradient?
      Cheers
        Are you talking about the curves that are used for example in the light intensity remap (for instance for the maya spot light) ?
        Alex Yolov
        Product Manager
        www.chaos.com
          I'm not sure what that is, sorry.
          Here's what I'm thinking of:
            I don't think that's possible. Can you do that for a regular maya ramp?
            Alex Yolov
            Product Manager
            www.chaos.com
              Nah, I don't think so either.
              I've used a remap to adjust the fresnel of a vray mtl, so thought it might be possible.
              For now, I'll create a grad which has the same settings as the curve and set the grad to 'smooth'.
                Well, most of things that are possible about how a regular ramp behaves should be possible with the softBox gradients. In fact, the control is similiar, if not the same, as any ramps available in other nodes.
                You can plug a remap between the texture and the gradient's ramp position, just like in any other ramp, if that suits your case. But you can't plug the remap after that.
                Alex Yolov
                Product Manager
                www.chaos.com
                  Cool, cheers.
                  Can you explain a bit more about 'You can plug a remap between the texture and the gradient's ramp position'
                  Cheers
                    Plotting the curve gives this result:
Name:	Screen Shot 2017-03-28 at 16.37.32.png
                      Originally posted by sherridge101 View Post
                      Cool, cheers.
                      Cheers
                      Here's what I mean - you can plug a remap or a remapRamp (from texture > effects) and then plug the result in the horizontal gradient. I don't know if that is going to work for you, though.
                      Alex Yolov
                      Product Manager
                      www.chaos.com
                        I don't see the Horizontal Gradient in the VRaySoftbox node?
                          Hmm, Maya seems to expose those only when they are connected. I've basically connected the textures to the color of the gradient positions in the attribute editor - then they are exposed as inputs in the node view like on my screenshot.
                          Alex Yolov
                          Product Manager
                          www.chaos.com
                            Hi Alex
                            Thanks for the info.
                            Tried plugging the remap in to all available Horizontal Gradient slots, but the ramp doesn't change/appear to be an available slot.
                            Cheers
                            • #15
                              Does it connect if you first select the position on the horizontal gradient and then connect your texture to the "selected color" slot?
                              Alex Yolov
                              Product Manager
                              www.chaos.com
