Does vrayDisplacement add a bump map effect?
  • Does vrayDisplacement add a bump map effect?
    Even if I set edge length to 10000 and max subdivs to 0, I get no geometry displacement on my mesh, but I still somehow get super fine bump-like detail. Does vrayDisplacement have some kind of bump effect that is independent of the subdivision of the mesh, like Arnolds autobump feature? How do I turn it off? I couldn't find anything about this on the forums or in the documentation.
    __
    https://surfaceimperfections.com/
    There shouldn't be such an effect from the displacement. Could you post some screenshots? You could also try adding a Normals and BumpNormals render element and check it with displacement enabled and disabled - Normals will contain any changes to the actual geometry made by proper displacement, BumpNormals will contain any changes to the geometric normals from bump-mapping.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Yes, it does compute bump out of the displacement.
      Enable the "Cache normals" option in the V-Ray displacement control attributes.
        Thanks Vlado! That's a very cool feature, although even knowing what to look for, the (otherwise immaculate) documentation is very unclear about Cache normals and what it does in practice . Debugging subdivisions and edge length is more difficult with it disabled.
        __
