Xen: Render Tubes Flat
  • Xen: Render Tubes Flat
    Hello,
    I am just working on a project using the Xgen to create grass
    everything works like a charm, only the grass looks more like seaweed
    I think it would be good to render the hair flat instead of tubes
    vimeo.com/219071675
    pwd: gr4ssX!
    (please don't spread its a client project)
    Autodesk support wrote this would be possible with Arnold, but I don't see that option in the VraaMtlHair3
    https://forums.autodesk.com/t5/maya-.../7111946#M5146
    Suggestions to make the grass look more like grass would be appreciated
    Thnx
    Martin
    From what I can see, they are rendered flat. In general, if you use a regular VRayMtl material, the strands will appear like a tube. If you use the VRayHairMtl material, they will appear flat.
      thnx I will give it a test and come back
        was this resolved? were having the same issues
          Nothing has changed. Using a VRayMtl will make the strands appear as tubes and using a HairMtl will make them appear flat.
          Alex Yolov
          Product Manager
          V-Ray for Maya, Chaos Player
          www.chaos.com
            were trying to do feathers and its rendering as tubes no matter what we do. We have tried every shader maya has. all tubes.
            Hair of course was used too
                top view
                  Try disabling embree from render settings > settings tab > System. (You can only choose to disable it for hair).
                  Alex Yolov
                  Product Manager
                  www.chaos.com
                    That seems to have worked. Thank you
