You can plug the softbox texture in the opacity slot of the material (if you're using a mesh plane) or in the Rect Tex A slot of the rectLight (if you're using a rect light). In the case of the rect light, you could save yourself a bit of trouble in the connection editor if you just put the softBox in a luminance node, which you can then plug into rectTexA. RectTexA is actually the alpha of the rect light.
Alex Yolov Product Manager V-Ray for Maya, Chaos Player www.chaos.com
