How to check all GPU cards are being used
  • How to check all GPU cards are being used
    Hi all
    Just wondering if there is a way to tell if all graphics cards are working.
    I use a GPU app to check temperatures, but wondering if there is a better way.
    Currently I select all 4 cards in open cl devices.
    A message displays saying ?The change will take effect the next time the V-Ray RT render server runs?.
    I launch ?V-Ray RT render server?
    When I render, the output window says the following:
    The 4th card isn?t listed.
    [2017/Sep/10|17:41:57] V-Ray: Total memory for device 1 : 6144 MB, free 5439 MB
    [2017/Sep/10|17:41:57] V-Ray: Building optimized CUDA kernel (0) for comp cap 3.5 for device 2...
    [2017/Sep/10|17:41:57] V-Ray: PTX file generated with CUDA Toolkit v7.5 for CUDA compute capability 2.0. CUDA runtime version 7050.
    [2017/Sep/10|17:41:58] V-Ray: Optimized CUDA kernel assembled successfully
    [2017/Sep/10|17:41:58] V-Ray: Total memory for device 2 : 6144 MB, free 5439 MB
    [2017/Sep/10|17:41:58] V-Ray: Building optimized CUDA kernel (0) for comp cap 3.5 for device 3...
    [2017/Sep/10|17:41:58] V-Ray: PTX file generated with CUDA Toolkit v7.5 for CUDA compute capability 2.0. CUDA runtime version 7050.
    [2017/Sep/10|17:41:59] V-Ray: Optimized CUDA kernel assembled successfully
    [2017/Sep/10|17:41:59] V-Ray: Total memory for device 3 : 6144 MB, free 5439 MB
    [2017/Sep/10|17:42:00] V-Ray: Progressive sampling base buffer memory usage: 5890.67 MB
    [2017/Sep/10|17:42:03] V-Ray: GPU adaptive lights built successfully
    Cheers
    Steve
    If you have done this with the "Select Devices for GPU Rendering" while you had Maya open, you'll need to restart Maya for the change to take effect. With 3.6 you can choose GPU devices from the Maya render settings without restarting Maya (in the VRay tab when you're using CUDA or OpenCL).
    There's third-party tools for monitoring the GPU loads (like EVGA Precision for example).
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Cool, cheers.
