Render settings showing all renders
  • Render settings showing all renders
    Hi folks.
    Just started to get an issue were the Render settings panel shows all the renders when I select vray as default renderer and the common tab stays on Maya software.
    Maya 2018 latest release 3.6. Its happened a couple of time now so will need to re-install vray to fix it.
    that is a very strange issue. If possible some more info might be very useful like how often does this happen?
    Do you use any custom workspaces inside Maya?
    Was this happening in older Maya versions like 2017/2018 update1/update2?
    Is VRay set as default renderer and do you have Arnold or any other render installed alongside with V-Ray?
    Thank you for your feedback!
    Ivan Shaykov
    chaos.com
      It was to do with render layers. Once I deleted the layer it then appeared as normal. So it was scene related as re instal didn’t make any difference. After deleting the layer I could creat a new one and so far so good. Will keep an eye out and will check when I go back to work tomorrow.
