Inherit colour to nparticle
  • Inherit colour to nparticle
    Hi folks.
    I'm trying to get my nparticles to inherit the base colour of the emitter (which is just a ramp mapped to a sphere)
    I have added the RGB PP in the Per Particle Attributes.
    On the emitter- I've turned on inherit color (assigning the sphere texture).
    But still not getting a result.
    What expression should be in the RGB PP slot?
    Thanks for any help!
    Hey stezza!
    Is your emitter type "Surface" ?
    Did you assgin "Out Color" of your Ramp to the Particle Color Input(it doesn't work if its VRayMaterial for example) ?
    Set your Particle render type to sphere, sometimes the color is hard to see as points.
    You don't need an expression for RGP PP if you inherit the color from the emitter.
    Maybe you can share a scene ?
    Kind Regards
    Pirmin
      I didnt have emitter set to surface but still not getting it.
      Heres a scene file....
        I don't know why, but I can't download the file, may you upload it to wetransfer ?
        Kind Regards
        Pirmin
          SampleScene.zip try this
          Google Drive is a free way to keep your files backed up and easy to reach from any phone, tablet, or computer. Start with 15GB of Google storage – free.
            I just added "Add Dynamic Attributes" -> "Color" -> "Add Per Particle Attribute" the RGB PP attribute and it worked.
              Awesome! thanks for taking a look for me, now I can move onto the next stage.
              Regards.
