VFB : setAttr ".vfbSA" -type "Int32Array"
  • VFB : setAttr ".vfbSA" -type "Int32Array"
    I've recently noticed that some of my scenes are bloated with this VFB data, thousands of these lines of numbers. Any idea of how to get rid of them from the scene without using a text editor?
    This is a snapshot.....the scene has over 65000 lines of these numbers.
    setAttr ".vfbSA" -type "Int32Array" 786696 3146779 17 -419 188 1829 1267
    -419 188 1130 620 -1073658879 1 1720 720 1 1134 965 455
    617 1023 0 1071757312 0 1071523840 0 1070362624 0 1070811136 1 382
    0 3146655 1 3 1 0 0 0 0 1 0 5
    0 1065353216 3 1 0 0 0 0 1 0 5 0
    1065353216 3 1 1065353216 0 0 0 1 0 5 0 1065353216
    1 3 2 1065353216 1065353216 1065353216 1065353216 1 0 5 0 0
    0 0 1 0 5 0 1065353216 1 137531 65536 1 1313131313
    65536 944879383 0 -525502228 1065353216 1621981420 1034594992 1057896689 1065353216 2 0 0
    -1097805629 -1097805629 1049678019 1049678019 0 2 1065353216 1065353216 -1097805629 -1097805629 1049678019 1049678019
    0 2 1 2 -1 0 0 0 1869047123 1230315621 0 0
    0 0 0 0 0 0 0 0 0 0 0 0
    0 0 0 0 0 0 0 0 0 16777215 0 70
    1 32 6 1819635240 403820 1848115200 694971509 2 64 1039835070 1039835070 1039835070
    1041096717 1040097332 1040097332 1042182136 1040275439 1040275439 1043249167 1040410596 1040410596 1044318211 1040545820 1040545820
    1045340145 1040678897 1040678897 1046362079 1040809961 1040809961 1047330795 1040943105 1040943105 1048293405 1041074169 1041074169
    1048887284 1041207313 1041207313 1049334800 1041338376 1041338376 1049758727 1041471520 1041471520 1050177519 1041602584 1041602584
    1050571784 1041735661 1041735661 1050959875 1041868805 1041868805 1051324410 1041997855 1041997855 1051681798 1042130932 1042130932
    1052021772 1042261995 1042261995 1052353524 1042393059 1042393059 1052667896 1042522109 1042522109 1052976127 1042653173 1042653173
    1053272077 1042782223 1042782223 1053560846 1042911207 1042911207 1053843442 1043040257 1043040257 1054119930 1043167227 1043167227
    1054394372 1043296277 1043296277 1054664720 1043425260 1043425260 1054934028 1043554311 1043554311 1055204342 1043679200 1043679200
    1055476737 1043808251 1043808251 1055750139 1043937301 1043937301 1056028674 1044062191 1044062191 1056309256 1044189161 1044189161
    1056598026 1044314117 1044314117 1056894983 1044439007 1044439007 1057082887 1044561950 1044561950 1057240576 1044684827 1044684827
    1057402879 1044807703 1044807703 1057569796 1044932593 1044932593 1057739782 1045053456 1045053456 1057915910 1045172238 1045172238
    1058094587 1045293034 1045293034 1058278918 1045413897 1045413897 1058464776 1045534693 1045534693 1058657798 1045655556 1045655556
    1058851323 1045774339 1045774339 1059049982 1045891041 1045891041 1059250168 1046009824 1046009824 1059454984 1046124513 1046124513
    1059660807 1046243296 1046243296 1059871227 1046357985 1046357985 1060082184 1046470661 1046470661 1060297721 1046587363 1046587363
    1060514298 1046702052 1046702052 1060733442 1046810634 1046810634 1060953089 1046925323 1046925323 1061176830 1047035919 1047035919
    1061400068 1047146514 1047146514 1061626376 1047257109 1047257109 1061853187 1047367705 1047367705 1062083068 1047474207 1047474207
    1062311423 1047582722 1047582722 1062542328 1047689223 1047689223 1062772729 1047797739 1047797739 1040097332 1041096717 1040097332
    1041096717 1041096717 1040097332 1042182136 1041229794 1040275439 1043249167 1041362938 1040410596 1044318211 1041496082 1040545820
    1045340145 1041627146 1040678897 1046362079 1041758209 1040809961 1047330795 1041891353 1040943105 1048293405 1042022417 1041074169
    1048887284 1042149387 1041207313 1049334800 1042282464 1041338376 1049758727 1042411514 1041471520 1050177519 1042544658 1041602584
    e: info@adriandenne.com
    w: www.adriandenne.com
    This piece of data holds the VFB settings, so that when you open the same scene, we can load in all the VFB color corrections and so on that you've tweaked. I think I can get you a simple script, but I need to test it first, I'll try and do that asap.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      awesome, that would be great, thanks
        OK, I thought I could try with a reset and re-save the scene, but it's not going to work. So there's no way to do that right now.
        Do you really need to not store this in the scene? When loading the scene later, you will loose your VFB color corrections if that wasn't stored in the scene file.
        Alex Yolov
        Product Manager
        www.chaos.com
          Ah, wait, I just remembered something. There's a reset VFB button in the render settings that will do almost exactly what you need. The vfbSA param block will still be in your file, but with only a few lines.
          You'll need to do this before any rendering happens in Maya, though. You'll need to open Maya and before doing any rendering, you can open your scene, reset VFB and save your scene.
          Alex Yolov
          Product Manager
          www.chaos.com
