Back shading with bump
  • Back shading with bump
    With back shading with bumps, light leaks.
    Click image for larger version  Name:	backside_bump.jpg Views:	2 Size:	96.0 KB ID:	1015519
    It can not be seen with 3ds Max or Maya GPU.
    Click image for larger version  Name:	backside_bump_3dsMax.jpg Views:	2 Size:	94.8 KB ID:	1015520
    V-Ray 4.04.01 With Maya 2018 confirmed.
    Probably this problem is from V-RayMaya 3.30 onwards.
    Attach Test scene
    qd.zip
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    someone at Chaos Guy?
    oakcorp.net
    v-ray.jp
      Yeah , have the same issue , I just cover the back or add thickness to mesh.
      https://www.artstation.com/damaggio
        I can confirm that. I wouldn't say it's a light leak, though, as it seems to be the bump itself calculated for the backside. I'm also unsure if this is normal behavior or not, so I'll need to run it through the devs before I can say anything.
        Alex Yolov
        Product Manager
        V-Ray for Maya, Chaos Player
        www.chaos.com
          It is wonder why it can be seen only with Maya CPU Production.
          oakcorp.net
          v-ray.jp
            We have reproduced the issue. We'll investigate why this happens and write back to you.
            V-Ray for Maya dev team lead
              This problem is obviously problematic with PolyHair and Cloth shading.
              want a workaround method
              Thanx
              oakcorp.net
              v-ray.jp
                I can't think of anything else than what damaggio suggested. I hope it will work for you.
                Alex Yolov
                Product Manager
                www.chaos.com
                  Ok.
                  There is no solution.
                  Please display a warning in the V-Ray log "There is a Single Side mesh with Bump in the scene!"
                  oakcorp.net
                  v-ray.jp
