VRay NEXT for Maya 2018 trial - NO GPU rendering available.
  • VRay NEXT for Maya 2018 trial - NO GPU rendering available.
    I just downloaded and installed the Vray NEXT trial for Maya 2018. Suddenly GPU is not available in the VRay "Production engine" tab in the render settings, only CPU shows up. I had 3.6 installed and it was rendering fine with GPU and CPU. Is this a known problem?
    Are you on Mac OS?
    You will need to edit your Maya.env tab to unhide the Cuda engine
    See here,
    https://forums.chaosgroup.com/forum/...it-from-the-ui
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Thanks Muhammed - yes, I am on a Mac, and i recall doing that with my other install. I'll try it out.
