Question: Caustics CPU render is blotchy, but with GPU or IPR fine - why?
  • Question: Caustics CPU render is blotchy, but with GPU or IPR fine - why?
    I am rendering a simple test scene.
    I get a good looking result when I render with IPR or CUDA.
    But with CPU render it looks blotchy.
    What's the reason? How to use the CPU rendering?
    The render time was almost the same (between 22 and 29 seconds).
    All using denoiser.
    Thanks
    The CPU/GPU IPR always uses BF+BF for GI
    But the production rendering uses BF+LC depending on the settings you use in your GI tab
    You can try to use BF+BF in your GI tab and see if this fixes the issue
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      And change the max render time to 0 in your render settings
      Muhammed Hamed
      chaos.com
        Are you using the irradiance map for GI? If yes, then it causes the blotchiness in the production rendering. Switch to brute force for primary bounces and light cache or brute force for the secondary bounces and it should be fine.
          BF+LC is not a problem. The irradiance map is.
            Hi, thanks,
            but it didn't solve to switch to BF+BF.
            Attached here the scene file and screenshots. I'm quite curious what could be the reason...
            The blotchiness comes not from rendertime, it comes up even in the first second. I set the max. rendertime also at 0 now.
            Just a related question:
            Is it o.k. to scale the LightRect? In old Vray versions I heard you need must only scale under VRayLightRectShape: Size > UV,
            but it seems not to make a difference anymore. (The RectLight in this scene, which causes the blotchiness, wasn't scaled).
            Ben
              In Caustic tab, uncheck on... and under GI, check Reflective Caustics.. it will render fine with BF+BF or BF+LC just like with Cuda engine
              Thing is that Caustics options are all hidden for GPU ui
              I'm not able to download your scene for some reason, but I made one that is very similar to yours and yeah having caustics on from Caustics tab produces this kind of noise
              I don't know if this is the intended behavior by devs or not.. you will have to wait for confirmation
              Scaling lights should be ok I think
              Muhammed Hamed
              chaos.com
                Thanks Muhammed, yes it nearly is the same, just that CPU is a bit darker. And that CPU takes 1.44min and CUDA only 33 seconds.
                I didn't realize, that caustics were hidden in CUDA, which means that they aren't raytraced at the moment.
                I can imagine, that to fight the blotchiness needs a lot more rendertime and try&error.
                But so far my main question is solved, I just needed to figure out what's the difference and why this happens.
                If someone has anything else to mention that we didn't see, I' would be glad.
                  The difference between CPU and Cuda engine is to be expected. They are 2 separate engines, the GPU code with written from scratch and optimized for GPU rendering
                  You will find other differences like normal mapping, displacement, SSS and such
                  The noise you got when you enabled the direct caustics doesn't seem to be a sampling issue. probably a bug, you will need to wait for confirmation from devs
                  Also keep in mind that the affect shadow options in your glass material is on by default, unlike Vray for 3Ds Max and Vray for Modo
                  So if you want to light an interior scene you will need to turn off affect shadows to get enough light into your interior.
                  Muhammed Hamed
                  chaos.com
