Help for finding the source of a VRay for Maya fairly generic error.
  • Help for finding the source of a VRay for Maya fairly generic error.
    Error is as follows:
    // Warning: V-Ray : Parameter transform doesn't exist! //
    Can't seem to locate what is firing it off. Any suggestions to help hunt it down? Even with vraySettings.sys_message_level at 4, I still just get that one line. Can't find the culprit.
    Any help appreciated.
    -Joel
    -Joel E
    https://www.biglittlepictures.com
    When and where the errors appears?
    When loading the scene, when rendering it, when loading Maya?
    Does it happen with every scene or with particular one/ones only?
    Try to isolate half of the objects in the scene and see if the error is still there, if yes continue with isolation until it disappears - this workflow should lead you to the culprit.
      Interesting enough, if i hide everything, it still does it. I have a feeling there may be a script node or something hidden. Got the source from an agency that may have a custom toolset that is missing on my end. Thanks for the help though!
      -Joel E
        It seems related to a texture described in the desc.txt file, but I'm not sure which texture it is; maybe an environment one? We really need to print more info.
          It seems you are correct. A light dome returns errors to the Script Editor for anything related to that node:
          setAttr "LightDomeShape1.enabled" 0;
          setAttr "LightDomeShape1.enabled" 1;
          setAttr "LightDomeShape1.shadows" 1;
          setAttr "LightDomeShape1.affectDiffuse" 0;
          setAttr "LightDomeShape1.affectDiffuse" 1;
          I'll just try to recreate it. That worked. No error now.
          -Joel E
            If it happens again, can you also post the log printed in Maya's output window and Maya's script editor - in particular the beginning of the log until Maya is fully initialized - it just might give us a clue if there's something wrong in the initialization phase.
            Alex Yolov
            Product Manager
            V-Ray for Maya, Chaos Player
            www.chaos.com
