Currently, wondering if there are any known limitations with Maya and Vray renderablecurves? I'm trying to render a bowl of noodles with SSS and the GI is giving strange results. SSS doesn't seem to work at all? Also, spec reflections on FastSSS are a little out of control.
SSS on Renderable Curve
They are Maya curves rendered with the vRay RenderableCurve Attributes
It didn't want to accept the maya binary file, so I uploaded to my server.
http://spectrl.io/sss_test.mbLast edited by bob dobbs; 19-03-2019, 10:53 AM. Reason: link wasn't saving correctly, included it in the body.
You were right there is something we need to fix, I reported the issue in our bug tracking system. For now, as a workaround, you can extrude geometry from those splines that you can use with the same shader or use AlSurface shader instead.Last edited by Zdravko.Keremidchiev; 21-03-2019, 02:21 AM.
Yeah its not ideal but you might attached paint effects brush to the curve and mesh it to tube, it should give you nice geo of the curve.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
