I'm currently experimenting with DWAB compression settings in V-Ray and I've ran into some problems when I take those renders to comp.
For this test, I've rendered four sets of images. 2 diffuse and 2 lighting pass. One set is rendered with Zip compression and the other set is rendered with DWAB compression set to 45.0. When I bring the DWAB images into my compositing software and divide the lighting by diffuse I get strange artifacts around the edges. I've also noticed these artifacts show up in very dark area of some renders too. The Zip compression showed no sign of these artifacts. Is there a workflow to mitigate or remove these artifacts through V-Ray?
Cheers
Cheers
