V-ray Next for Maya 2019, GPU cuda not available
  • V-ray Next for Maya 2019, GPU cuda not available
    I've applied update 1 to Next for Maya 2019. Also logged in as root and ran the "vray_gpu_device_select" service to set the GPU (titan X). But GPU/cuda rendering is not available in render settings. Anything else that needs to be set?
    What is the OS that you are using? Please note that V-Ray GPU works only with C++/CPU devices under macOS.
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
      Mac OS 10.13.6. The first version of NEXT worked just fine with GPU in Maya 2018.
        You can enable the option by setting the environment variable VRAY_MAC_GPU to 1 in your Maya.env file.
        The Cuda engine is still supported on Mac OS by Chaos Group, and it works nicely here
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          To add: it appears that update 1 to NEXT has broken GPU rendering for me, even in Maya 2018. In Maya 2018, I can select GPU rendering, but when trying to render, it completely hangs after "compiling kernels for device GeForce GTX TITAN X"
            Muhammed_Hamed thanks for that reminder - that did enable CUDA rendering. I guess the compiling kernels step was a one-time thing?
              Yeah, it happens once I think, then rendering should be instant.
              Muhammed Hamed
              chaos.com
