render in ACES with substance painter textures
  • render in ACES with substance painter textures
    Having a bit of issue getting Substance Painter output textures to render as expected with ACES in Maya. I am using the preview sphere that comes with Substance Painter to export a set of textures using Vray UDIM preset that comes with SP. An ACES LUT is used in Substance Painter just for viewport preview, not affecting output textures AFAIK.
    Questions 1: should I convert the color maps (diffuse and reflection color) from sRGB to ACEScg in Nuke first?
    Questions 2: should the Displace Device color transform in VFB OCIO be sRGB, instead of ACES? The dropdown menu doesn't provide any other option other than ACES.
    Questions 3: what's the pros and cons of bringing in textures as is and then use VrayOCIO node to do the color space conversion in the Hypershade?
    Thanks!
    always curious...
    I did a few more tests and found a couple of approaches that provide an acceptable match to SP viewport.
    First, I use Arnold 5 UDIM (AiStandard) export preset in Substance Painter to output textures as I am able to get better-matched results with them instead of using Vray UDIM preset for the texture export.
    Approach A:
    SP texture export setting: Arnold 5 UDIM (AiStandard)
    no color space conversion in Nuke before plugging maps in Maya
    Maya texture file node color space settings:
    color texture: utility - sRGB - Texture
    data texture: utility - Raw
    hdr: utility - Raw
    VFB OCIO settings:
    Input Colorspace Utililty - Linear - sRGB
    Display Device: ACES
    View Transform: sRGB
    Nuke read node colorspace: Utility - Linear - sRGB
    Approach B
    texture color space conversion in Nuke
    convert diffuse map from Utililty - sRGB - Texture to ACEcg with sRGB color profile baked through the Write node
    convert HDR map from Utility - Linear - sRGB to ACEScg
    color texture: ACEScg
    hdr: ACEScg
    VFB OCIO settings:
    Input Colorspace: ACEScg
    Nuke read node colorspace: ACEScg
    always curious...
