Hello,
I've been having an issue rendering with IPR in Maya 2018.
I have a large asset (a few dozen UDIM textures) - the IPR works fine and as expected, with the exception of a few pieces of geometry not rendering RGB (alpha shows up as solid).
The asset is a bridge that is coming from Substance - there is one master shader for everything, with multiple maps going into it (standard components like diffuse, spec, etc, but also glossiness, IOR, etc).
The missing pieces of the asset render fine in CPU IRP or CPU production.
Looking in the V-Ray RT output console (using out-of-process IPR so I can view everything), I don't see any exceptions or errors.
I've tried caching / clearing caching of textures and geo between frames. I've tried setting the mipmap resolution to 512 and native both in the IPR options and also the V-Ray IPR options.
The textures are 16-bit half EXRs, though I've left the IPR texture bit depth at 8-bit as it's yet to be an issue (will be setting to 16-bit half now and see what happens).
Not sure if the 'keep textures cached between renders' option is relevant for IPR.
Would really like to be able to light interactively for this shot - any advice is greatly appreciated. I don't see any issues with the geometry itself, as it renders fine with a different shader attached.
Any advice or troubleshooting tips is greatly appreciated!
Thanks.
Thanks.
