Refraction affect allChannels = wrong AOV's and light select with another value that 1 in refraction glossiness.
  • Refraction affect allChannels = wrong AOV's and light select with another value that 1 in refraction glossiness.
    Hello VRay Dev Team,
    I did a simple scene, 2 spheres, 1 domeLight, 1 plane, no maps, when I see the first sphere across the second fully refracted (refraction glossiness=1) sphere, my beauty is OK and my GI AOV is OK. If I set the refraction glossiness to another value that 1, my GI AOV is fully black. It's the the same for the SSS etc.. I dont have right now the time to do the same contactsheet for all the light_select mode but it is the same bug...
    It is a VRayMtl basic fully refracted with affect 'allchannels' in refraction tab and 'affectShadows' checked ON.
    Have you the same bug?
    Is there an update of my VRay version for this?
    I use Maya 2018.6.
    Thank you for advance,
    Edouard
    Thanks for the report. I've forwarded the issue (Bug-tracker id: VMAYA-9061) to our developers for further investigation.
      Hello Chaosgroup,
      Do you have an answer about that?
      For the moment VRay cannot make a back to beauty with blurry refraction. Very limited for working. No changes in the new upgrade 4.3...
      Thank you,
      Edouard
        The issue is not yet fixed. You'll be informed when there is movement on the case.
