moving vrscene elements with ipr does not refresh
  • moving vrscene elements with ipr does not refresh
    Just a quick one, not sure if it's a bug but if one has a vrscene element in a scene (say a tree) and when attempting to movie it around, it does not update when IPR is running. Thanks
    Maya 2020/2022
    Win 10x64
    Vray 5
    Thanks for the report. We are aware of that issue.
    There is an alternative load mode that you might find useful in some cases.
    If you are using the .vrscene file to import geometry and shading only, you can change the VRayScene Load Mode to Geometry. This mode has several advantages, especially for instanced geometry, and it allows transformations applied to the vrscene to be updated without restarting the IPR. It was introduced in V-Ray Next, Update 1.
    Hope that helps you!
    Svetlana Gesheva
    QA, V-Ray for Maya
    chaos
