According to this documentation, I should be able to put a object+material set into the set slot and have it automatically only render those materials into a layer for me. But it doesn't work at all, just remains black. I have several characters with fur, in post, we like to take the fur pass and micro blur and double it for desired client effect. Material select worked fine as solo character. After referenced with several characters, I can't use just the one fur, I would have to use the referenced fur per-character. In theory, the material pass should still work if i make a set with all the fur materials in it, but it just renders black. Any insights?
Should the material slot be left blank and then the Materials slot have the set in it... this is correct right?
https://docs.chaosgroup.com/display/...aterial+Select
