Crash with V-Ray 4.30.01
  • Crash with V-Ray 4.30.01
    Hey there,
    this is a strange one. The attached scene renders fine with 4.12.01 but it crashes with 4.30.01.
    Steps to reproduce:
    1. Open Maya file
    2. Make sure the included texture file is loaded.
    3. Render
    It seems a combination of the two objects and the shaders cause the crash.
    Renders fine if:
    - each object alone
    - or if Opacity Mode in the shader dust_mat_general is set to either Normal or Clip
    - or if there is no Opacity Map connected to shader dust_mat_general
    - or if Roughness Amount of shader dust_mat_general is 0
    or if the Refraction of shader Lens_Red is 0
    - when using V-Ray 4.12.01
    Maya 2019.2
    V-Ray 4.30.01 / 4.12.01
    Windows 10
    Florian von Behr
    CG Supervisor
    The Scope GmbH
    Behance
    Thanks for the report. The issue is reproducible, I've logged it (internal bug-tracked id: VMAYA-9281) for debugging.
      Great. Would it be possible to get a notification once this bug is fixed in the nightlies?
      Florian von Behr
      CG Supervisor
      The Scope GmbH
      Behance
        Not directly, however, I can notify you when there is movement on the matter.
