Volume Grid issues - No light linking?
  • Volume Grid issues - No light linking?
    Hello, help needed.
    I'm not able to create light links with the volume grid - this is proving to be a bit of a pain on the shots were working on which featrue .vdb smoke sims. The volume grid does not show up in the relationship editor. Pease see below example of basic scene.
    Thanks in advance for any suggestions.
    -maya 2017
    -VRay Next Update 2.1
    First of all, you can see the VolumeGrid under the initialShadingGroup (click on the plus sign). Otherwise, there seems to be an issue with light linking the VolumeGrid with the 'Light centric light linking', which we will investigate. However, linking through the 'Object centric light linking' seems to work properly, so give it a try.
      thanks, sorted. and yes doesn't work when linking via 'light centric linking'
