jpeg textures not working
  • jpeg textures not working
    Click image for larger version  Name:	2020-03-02 13_59_20-.jpg Views:	1 Size:	27.6 KB ID:	1063078
    Hi, is there a reason why any jpg texture in a scene would render jet 100% black? Just a jpg plugged into a default VrayMtl.
    No matter the jpeg, a simple plane and simple material is 100% black
    Maya 2020/2022
    Win 10x64
    Vray 5
    viewport:
Name:	2020-03-02 14_06_30-16_19_cq2_atrium_v20.ma_ - Autodesk Maya 2020_ G__MayRussellData_2018 PROJECTS_1.jpg
    no idea what's going on, default uvmap1 as well
    Maya 2020/2022
    Win 10x64
    Vray 5
      check that object has uvs on map1 and not some random uv channel some times that might cause an issue. You can also verify that texture is working by applying the same shader to default maya object like poly plane.
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
        yeah, JPG should work, we use it quite often without any problem.
        www.mirage-cg.com
          What about format, is ir RGB? Or CMYK/other ? Maybe its unsupported format?
          What about Ammount, maybe its 0?
