Spherical panorama stereo issues.
  • Spherical panorama stereo issues.
    Hello.
    While testing Vray spherical stereo rendering we have found some issues. Lets start from first one - it seems that "Interocular method" option isn`t working.. so Vray always make camera shifting based on central camera.
    This is very handy option for our pipeline. Is it possible to fix that ?
    Thank you..
    No chance to resolve it?
      Any update on this issue?
      We use vray next 3.2 for 3ds max and the "interocular method" is broken there also. As namaissur said, it just renders as though "shift both" is selected...
      Set V-Ray class properties en masse with the VMC script
      Follow me for script updates: @ollyspolys
        Hi all,
        If you want to make only the left or right projection to change, you will need to halve the interocular distance. For example - if the default eye distance value is 6.5, set it to 3.25 and select either the Shift right or Shift left option. If that's not the case, please provide more details on the desired effect - any screenshots will be greatly appreciated.
        Nikoleta Garkova | chaos.com
